-   -   84 911Valve adjustment (http://forums.pelicanparts.com/911-engine-rebuilding-forum/844293-84-911valve-adjustment.html)
hyperkinesis 12-28-2014 04:43 AM
Hi
I need to know the valve adjustment clearance for my 1984 Porsche 911 targa.
and the tool I need to make this job, any other suggestion to verify my motor?
now the engine is open to change damage valve how I increase HP increasing the pressure?
The car for a bad gears set at high speed from 3rd gear at 100mph changes from 3rd to 2nd making a over rpms
TheSt|G 12-30-2014 07:42 AM
Are you saying you money shifted and want to know if a valve adjustment will fix the damage?
afterburn 549 01-01-2015 06:55 AM
Trying to understand your post -
The valve clearance will be the same no matter what else you may do to the engine.
hyperkinesis 01-02-2015 02:04 PM
I need to know the correct valve clearence
Flat6pac 01-02-2015 02:19 PM
.1 mm
