-   -   Is a 3.6 as robust as a 3.2/930 for big turbo power? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/845245-3-6-robust-3-2-930-big-turbo-power.html)
Tippy 01-03-2015 09:24 PM
Always wondered how much power a 3.6 can take with stock rods and crank (head studs?) barring you stay at the OEM redline.
On a side note, I have a 3.2 converted to 3.4 (est. 600+hp), but long sometimes for a really big bore engine nudging close to or at 4.0.
Is this super exotic or the same as going from 3.2 to 3.4? Just P's & C's?
Will a stock 3.6 and up take around 2 bar of boost if one chooses, or will the cylinders be hand grenades at this point?
Really curious. TIA. :)
saxen 01-03-2015 09:38 PM
Sub"d
totle 01-04-2015 03:21 AM
Hi Tippy,
Guess you are decreasing the CR?
A friend here in Norway build a 3.3 or 3.4 out of a NA 3.6 by installing a 3.0 crank, it gives a CR of 8:1 (or was it 8:5:1 ?)
He says that the 3.6 P/C are very good. He makes 5-600 hp with 3.0 crank and 964 cams
Tippy 01-04-2015 05:40 AM
Hello Totle, yes I have Max Moritz pistons and Mahle cylinders dropping down to 7.5:1 CR.
Raceboy 01-04-2015 09:45 AM
Isn't 7.5:1 too low? With todays engine management, I would not go below 8.5:1 to get the best driveability...
