-   -   IMS bearing change- 5 chain (http://forums.pelicanparts.com/911-engine-rebuilding-forum/845477-ims-bearing-change-5-chain.html)
Naed 01-05-2015 10:43 AM
In reading the tech doc for replacing the IMS bearing, engine in car (2003 911/996) it says to release only two of the three chain tensioners. It leaves out the chain tensioner that is below the air compressor pump. Am I accurate in assuming that because the gear is locked down and on the other end of the shaft it takes that out of the question?
Also, has anyone tried locking down the cams with the LN tool prior to locking down the sprocket with three bolts? Curious if there are holes in that position, it would add a layer of assuring the timing would remain constant/unchanged if I can lock cams first no?
Thank you.
Naed
FPB111 01-05-2015 12:12 PM
Naed,
You should lock the cams with the LN tool and also "pin" the crank at TDC.
I did that and was successful with only removing the two flywheel end tensioners on my 2003 3.6ltr C2 Cab.
I also picked up one of these tools that made the job much easier.
Sir tools SIR-P254 engine support bar
Please read this thread.
http://forums.pelicanparts.com/porsche-996-997-991-forum/844084-cant-rotate-engine-after-ims-bearing-change.htmlhttp://forums.pelicanparts.com/uploa...1420488695.jpg
Naed 01-05-2015 01:15 PM
Thanks for the follow up, great to hear! Will be ordering the LN tool kit/bearing not to mention clutch etc. Next weekends project. I like the engine holder too. thnx again.
