964 engine wiring question
porsche 964 engine M64/01 "whitout gaskets"
hi/ciao, please, this is the wires on engine for alternator/iniectors ecc, the final part is fired... What is missing? I see the red cable of the alternator and the other two (injectors?) I could not find the code porsche ... although I hope to find the attacks end are on the left side I guess go to the control unit? thanks! http://forums.pelicanparts.com/uploa...1420735729.jpg http://forums.pelicanparts.com/uploa...1420735743.jpg |
new pics!
the red is alternator....the Others? http://forums.pelicanparts.com/uploa...1425897552.jpg http://forums.pelicanparts.com/uploa...1425897596.jpg |
Heavy red to starter from alternator
Yellow starter Small black. Reverse switch Little ones. Oil temp and pressure Back of alternator Red is +, blue is gauge. Right next to red Alt ground is about 1/2 way around from + Fuel rails are injector wires You need a good harness Bruce |
Hi FLAT very very thanks! but , very sorry and please....my english its terrible...look the pics:
the small green temp+pressure ok A red alternator B starter C D E F thanks! GRAZIE!! http://forums.pelicanparts.com/uploa...1426089667.jpg |
Wiring 964 oil and starter wiresp
Wiring
| All times are GMT -8. The time now is 06:43 PM. |
