-   -   Help ID these jugs (http://forums.pelicanparts.com/911-engine-rebuilding-forum/847367-help-id-these-jugs.html)
Mark Wilson 01-18-2015 12:49 PM
Help ID these jugs
They've been in a box in the garage for years and I can't remember what they are or how I ended up with them. They are stamped 84 std and have wrist pins. Any idea what they are and their value? I'm thinning out my stuff. thx
http://forums.pelicanparts.com/uploa...1421614093.jpg
http://forums.pelicanparts.com/uploa...1421614106.jpg
http://forums.pelicanparts.com/uploa...1421614123.jpg
tom1394racing 01-18-2015 03:28 PM
Those appear to be either 2.2T or 2.4T pistons and cylinders. There should be a casting number inside the piston that will begin with 84P. The cylinders look to be 84 mm cast iron. They will have a casting number near base.
cmonref 01-18-2015 04:51 PM
Pelican shows those head gaskets are for 1970-73 911. 2.2L - 2.4L as Tom says.
Mark Wilson 01-19-2015 10:46 AM
Thanks - The jugs are painted black outside, so I doubt they're Mahle. I'll take a look at the skirts.
Steve@Rennsport 01-19-2015 04:59 PM
Check the bores with a magnet; they might be some kind of Biral-type cylinder. QSC maybe?
Lapkritis 01-20-2015 07:53 AM
I doubt QSC.
The clips aren't what QSC uses and they don't machine the groove for the CE ring on top last I checked.
