-   -   930 rebuild (http://forums.pelicanparts.com/911-engine-rebuilding-forum/847413-930-rebuild.html)
sundevil64 01-18-2015 06:53 PM
930 rebuild
I posted this over on the 930 forum also.
I am going to have to open up the motor on my 930 as I strongly suspect a bad bearing.
In contemplation of this large and expensive project I had a few questions.
What are my bearing choices for a 930 crank? IIRC I have ready several post where the bearings currently available are not what they used to be?
I was thinking about going to a 964 or GT3 crank should my 930 crank need work. Thoughts on that? IIRC the GT3 crank will need more clearance in the case.
How good is a crank repair of welding, turning back to correct size, and hardening?
The use for this car is street only with some spirited hill country roads in a 78 sunroof delete mostly stock Euro 930 (has SC cams and 993 heat exchangers).
Thank you in advance.
John
turbobrat930 01-19-2015 05:05 AM
send me a pm with your phone number... I have been through this. we need to chat. will save you some heartache and money
