Crankshaft housing case gasket
hello,
I removed the cover from my passenger side camshaft housing . on my Porsche 911 SC 1983. my question I have to put the new gasket is what I have to stick with clue it and if so what product I use. thank you !!! |
Apply dry and tighten fron center out.
Bruce |
Crankshaft housing gasket your tips please
hello,
I removed the cover from my passenger side camshaft housing . on my Porsche 911 SC 1983. my question I have to put the new gasket is what I have to stick it and if so what product I use. thank you !!! |
Hi,
Did you remove the cover from the passenger side camshaft? On your Porsche SC 1983? Your question you had about putting the new gasket on and what product to use to stick it? Flat6pac said none....nada. You are welcome? Thank him.
'77 911S Coupe 3.2 Turbo '76 911S Coupe 3.0 964 cams...no sunroof '75 911S Cabbie 3.2 SS Web cams & 46mm Webers '73 914 1.7 Webers & Header ... sold '74 VW 1303S 1600cc DP Web 110 & Solex |
I believe English is not his first language. Check out his location. Maybe even used a translator.
Install "sec". |
Thanks,
No clue just the new gasket !!! |
Thanks,
