roadster49's Avatar
1983 SC intake backfire solution
My 1983 911 SC backfired through the intake and exploded the air box. I have purchased a new air box and will drop the engine and rebuild when the weather warms a bit here in Michigan.
I would like to eliminate the chance of the backfire recurring and found this article on Rennlist.
CIS cold surging and backfiring - the final solution - Rennlist Discussion Forums
I would like to hear comments on this suggestion.
Thank you
Michael
Old 01-31-2015, 02:14 PM
Roadster,
I would suggest moving this post over to the 911 tech forum. More viewers there and a couple of real CIS gurus. If you could get "psalt" to chime in, you would be fortunate.
Good luck
Old 01-31-2015, 02:55 PM
Got a couple things to look at besides a pop off valve
You're running lean or the distributor is not set up correctly or working as designed.
Bruce
Old 02-01-2015, 01:44 AM
