-   -   Head Stud Depth (http://forums.pelicanparts.com/911-engine-rebuilding-forum/849946-head-stud-depth.html)
chris_seven 02-03-2015 08:08 AM
Head Stud Depth
Following on from debates about 'bottoming' studs and the new generation of Cosworth Subaru Head Studs which have a base feature we are starting to model the threads in the case, the stud and the head joint.
If we produce a good 3-D model we can export it ANSYS build the preload in and 'warm it up' to look at the stresses.
One thing I have little or no data about is the depth of the blind stud holes in the various generations of engine case and the variations.
I have early Aluminium Cases, early mag cases, 5R/7R cases, Carrera 3 cases and SC cases but I don't have any 3.2 cases.
has anyone every made any measurements of the depth of blind hole and the depth of thread?
Any data would be helpful.
356RS 02-03-2015 09:24 AM
Chris, I measured a 930/25 case ( 1987 3.2 ) and found the head stud case hole to be 34.75mm to 35.00mm total depth. The bottom of the hole has an un-threaded area of 6.5mm in depth. The studs are 163.75 to 164.00mm in length and the case end threaded portion is 25mm in length.
chris_seven 02-06-2015 06:00 AM
Mark,
Thanks that's virtually identical to the SC case.
