3.2 engine build
So, I have just purchased a used 3.2 Carrera engine from a crash damaged 911 from 1987.
Its currently being shipped back to the UK and the plan is to rebuild and use in my 1971 VW bus conversion. I already have a 915 transmission. So a couple of questions. I have seen "Euro" and "USA" replacement cylinders and pistons with the Euro versions being rated to a higher BHP. Is this due to emissions and therefore can be replaced with the euro versions? Next, I am converting to jenvey ITB's and Omex ignition and fueling. What cam would be well suited to this? Last, I think the engine was originally fitted to a G50 transmission, what do I need to change to make it work with the 915? Any help appreciated |
83 911 Production Cab #10
In case you have not seen this: Porsche Powered Mid-Engine Double Cab Also, you might want to post that question here: Porsche Engine Conversion Tech Forum - Pelican Parts Technical BBS
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Project Addicted
The 3.2 will fit the 915 but you will need a clutch kit from and '86 or earlier car and a flywheel too.
Jon 1966 912 1976 911 3.4 Backdate Project 1986 944 |
The 3.2 should make right at 235 hp in an American build config. I doubt that for your application in a bus, that any slight increase in power will be relevant. You are going to have a hot rod with either engine build! So, go for whichever build is the most economic.
Ernie 98 993 C2S - Arena Red/Beige 76 914/6 3.2 Conversion - Estorill Blue/Coral Red |
Thanks for the advice |
Thanks guys, already looking at euro pistons and barrels. So what is the right cams to go with?
Oh and is there any difference between standard 3.2 barrels and pistons and Carrera ones?
Project Addicted
NO, not for that engine.
964 cams might be a good swap once you're in there.
great, thanks, so any 3.2 barrels and pistons for an 87 will work, great
Project Addicted
Yes, for any original 3.2 from 1984 to 1989 should all be good. New pistons will fit in your existing barrels BTW. You can have them replated.
Oh cool, didn't know that.
Is it a good idea to fit an external oil cooler or is the Porsche one ok? I come from a VW world where the internal cooling is not "optimal" for bigger engines. |
Oh and another one... head studs. Do I need to replace and if so, what is a good replacement for the Dilavar ones that break?
Project Addicted
Yes, the 3.2 will need an external cooler. The one on the engine is not adequate for the 3.2.
The bottom head studs will need to replaced at a minimum. I''m using stock steel studs for my engine build, but if you want to go full Monty then Supertec studs or ARP studs. Works of are these are...
Project Addicted
Right here at Pelican or many many other vendors.
Project Addicted
I'm using part number 911 101 17200
You need 12 of them
Thanks a lot, really helpful.
So, for the external oil cooler what is the routing? Engine to cooler and then back to tank or something else? And do I need an external oil thermostat? |
Project Addicted
You can use the Porsche thermostat or one from say, Mocal and one of their coolers too. With all of the under floor space you may be able to mount it close to the engine and run an air duct to it to feed it while moving. Lots of ways to skin that cat and you will have to be good at fabrication too!
I have a great fabricator so no problem there. So how is would the oil line routing work? Would the line go from the engine outlet to the cooler and then back to the tank?
I would be interested what other builders say, but I think that if you're going with Jenvey ITBs, then you might want to go with a more aggressive cam profile like a DC40 or modified S cam. The potential problem you might find is the piston to valve clearance with either the US or Euro pistons. For that reason, you might consider higher domed pistons like JE or another brand. Interested what others think. If you go with Motronic, then the US or Euro pistons would be great. Another option is to send cylinders to EBS and have them slightly bored and plated so that you can run 3.4 pistons, and then you can get new JE pistons. I think it is cost effective if you can find a cheap set of 3.2 cylinders..
