-   -   3.2 engine build (http://forums.pelicanparts.com/911-engine-rebuilding-forum/850445-3-2-engine-build.html)
dpetteng 02-06-2015 12:56 PM
3.2 engine build
So, I have just purchased a used 3.2 Carrera engine from a crash damaged 911 from 1987.
Its currently being shipped back to the UK and the plan is to rebuild and use in my 1971 VW bus conversion. I already have a 915 transmission.
So a couple of questions.
I have seen "Euro" and "USA" replacement cylinders and pistons with the Euro versions being rated to a higher BHP. Is this due to emissions and therefore can be replaced with the euro versions?
Next, I am converting to jenvey ITB's and Omex ignition and fueling. What cam would be well suited to this?
Last, I think the engine was originally fitted to a G50 transmission, what do I need to change to make it work with the 915?
Any help appreciated
JJ 911SC 02-06-2015 02:23 PM
Originally Posted by dpetteng (Post 8474601)
... and the plan is to rebuild and use in my 1971 VW bus conversion. I already have a 915 transmission...
This is going to be fun...
In case you have not seen this: http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/524564-porsche-powered-mid-engine-double-cab.html
Also, you might want to post that question here: Porsche Engine Conversion Tech Forum - Pelican Parts Technical BBS
Jcslocum 02-06-2015 03:18 PM
The euro pistons will fit. A slight bump on CR so the greater powah!
The 3.2 will fit the 915 but you will need a clutch kit from and '86 or earlier car and a flywheel too.
earossi 02-08-2015 05:08 AM
The 3.2 should make right at 235 hp in an American build config. I doubt that for your application in a bus, that any slight increase in power will be relevant. You are going to have a hot rod with either engine build! So, go for whichever build is the most economic.
dpetteng 02-08-2015 07:55 AM
Originally Posted by JJ 911SC (Post 8474798)
Wow, that mid engine thing is awesome!
Thanks for the advice
dpetteng 02-08-2015 07:57 AM
Thanks guys, already looking at euro pistons and barrels. So what is the right cams to go with?
dpetteng 02-08-2015 08:01 AM
Oh and is there any difference between standard 3.2 barrels and pistons and Carrera ones?
Jcslocum 02-08-2015 08:10 AM
NO, not for that engine.
964 cams might be a good swap once you're in there.
dpetteng 02-08-2015 08:25 AM
great, thanks, so any 3.2 barrels and pistons for an 87 will work, great
Jcslocum 02-08-2015 08:30 AM
Yes, for any original 3.2 from 1984 to 1989 should all be good. New pistons will fit in your existing barrels BTW. You can have them replated.
dpetteng 02-08-2015 08:51 AM
Oh cool, didn't know that.
Is it a good idea to fit an external oil cooler or is the Porsche one ok? I come from a VW world where the internal cooling is not "optimal" for bigger engines.
dpetteng 02-08-2015 09:25 AM
Oh and another one... head studs. Do I need to replace and if so, what is a good replacement for the Dilavar ones that break?
Jcslocum 02-08-2015 10:00 AM
Yes, the 3.2 will need an external cooler. The one on the engine is not adequate for the 3.2.
The bottom head studs will need to replaced at a minimum. I''m using stock steel studs for my engine build, but if you want to go full Monty then Supertec studs or ARP studs. Works of are these are...
dpetteng 02-08-2015 12:22 PM
Any idea where you can buy the stock steel studs?
Jcslocum 02-08-2015 05:22 PM
Right here at Pelican or many many other vendors.
Jcslocum 02-09-2015 06:18 AM
I'm using part number 911 101 17200
You need 12 of them
dpetteng 02-10-2015 04:49 AM
Thanks a lot, really helpful.
So, for the external oil cooler what is the routing? Engine to cooler and then back to tank or something else? And do I need an external oil thermostat?
Jcslocum 02-10-2015 05:12 AM
You can use the Porsche thermostat or one from say, Mocal and one of their coolers too. With all of the under floor space you may be able to mount it close to the engine and run an air duct to it to feed it while moving. Lots of ways to skin that cat and you will have to be good at fabrication too!
dpetteng 02-10-2015 08:13 AM
I have a great fabricator so no problem there. So how is would the oil line routing work? Would the line go from the engine outlet to the cooler and then back to the tank?
MST0118 02-10-2015 08:59 AM
I would be interested what other builders say, but I think that if you're going with Jenvey ITBs, then you might want to go with a more aggressive cam profile like a DC40 or modified S cam. The potential problem you might find is the piston to valve clearance with either the US or Euro pistons. For that reason, you might consider higher domed pistons like JE or another brand. Interested what others think. If you go with Motronic, then the US or Euro pistons would be great. Another option is to send cylinders to EBS and have them slightly bored and plated so that you can run 3.4 pistons, and then you can get new JE pistons. I think it is cost effective if you can find a cheap set of 3.2 cylinders..
dpetteng 02-10-2015 09:27 AM
So could I have my old barrels made useful for JE pistons?
dpetteng 02-10-2015 09:31 AM
Anyone got any experience of these QSC kits?
TheSamba.com :: VW Classifieds - QSC Porsche 911 Nikasil Pistons/Cylinders Set
Jcslocum 02-10-2015 09:34 AM
Yup, you can get your existing barrels over-bored and replated with Nikasil. You can go 3.4 all the way up to 3.7 I think. 3.7 might need some machine work on the case tho. The JE pistons are an excellent option! I'm using them on my 3.4 build.
Once you go bigger you will have to being looking at twin plugging the heads due to the bore size and the offset position of the spark plug. I will also send you an email or PM. You are entering the slippery slope of while I'm in there......
dpetteng 02-10-2015 09:42 AM
So if I wanted to stay close to 3.2 I would have the cylinders bored as little as possible and find a JE piston to fit?
Jcslocum 02-10-2015 09:46 AM
No, no, no not QSC parts.....
Buy some JE 3.4 pistons PORSCHE - PORSCHE 911 (Automotive Section) - JE Pistons
Send them to Millenium technologies and have them bored and plated to fit.
I think the 9.5:1 can get away without twin plug.
dpetteng 02-10-2015 09:52 AM
So that would be better than Euro Mahle 3.2 pistons and barrels?
What kinda ballpark costs would there be for boring and plating?
