-   -   Porsche 3.2 Cylinders restored? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/850981-porsche-3-2-cylinders-restored.html)
turbotoo 02-10-2015 05:49 AM
Hello. Does anyone know a shop that can restore Porsche 3.2 Cylinders preferably in Florida. Thanks in advance.
Jcslocum 02-10-2015 06:48 AM
If you mean replate, then there are just a few places that I know of. I have used and would recommend Millenium Technologies in MI to do this for you. All of this will depend on the type of cylinder you have. Nikasil or Alusil. You can usually tell by who made them as to what coating they have. Other will know much more than I.
Pellesin 02-11-2015 01:42 AM
A good tip from MR Dempsey`s book is that the nikasil plating is slitely magnetic and the Alusil isn`t. Sneek one of youre wifes refrigerator magnets out in the garage and check if it will stick-atleast be "interrested" in the surface of the cylinder. If it is=nikasil, it it isn`t=Alusil.
This being a 3,2 I would assume nikasil, but you should never trust assumpions...
chris_seven 02-11-2015 03:35 AM
It is relatively common practice to Nikasil plate onto Alusil Cylinders, clearly having ground the cylinder first.
We have only run these cylinders with Aftermarket pistons and rings to suit Nikasil cylinders (Woessner) but I believe you can fit Goetze rings to KS pistons and they run well.
There is a small difference in expansion between the KS piston and the Mahle piston so making sure the clearance is correct is important.
turbotoo 02-11-2015 04:48 AM
Thanks guys! I really appreciate the info. I'm having trouble with he guy that rebuilding my engine. Any recommendations for Florida?
Jcslocum 02-11-2015 05:02 AM
Full on rebuild or just the top end??
The top you can probably do if you have some skills, but the full engine should prolly be sent out.
I can't help you there.....
turbotoo 02-11-2015 05:03 AM
I have 0 skills :( and want to do a complete rebuild.
WERK I 02-11-2015 02:56 PM
Haven't used this company yet, but plan to send out some C2 Turbo cylinders to them in the Spring. Like any automotive machining/services, find references and go from there......
Plated Cylinder Services | Plating Honing Repair | Piston Coating | Big Bore Kits | Motorcycles | Snowmobiles | Dirt Bikes | Rebuild | Replace | U.S. Chrome Corporation of Wisconsin Cylinder Repair Company
Walt Fricke 02-12-2015 12:07 AM
US Chrome did a good job turning my 95mm Alusils into Nikasils. Plenty of experience.
Dr J 02-13-2015 09:16 PM
For an engine rebuild in Florida I would contact Mike Bruns of JB Racing. They are near Orlando.
Amstaff 02-14-2015 08:18 AM
+1 for JB Racing
DSPTurtle 02-15-2015 06:09 AM
We can replate and rebuild your motor. Nikisil is a trade marked name so the replated cylinder surface has a different name. Goetze rings will work just fine. Are you trying to go oversize on your engine?
We are on the east coast by the way.
turbotoo 02-15-2015 06:10 AM
No, just trying to have it rebuilt and show looking condition.
Discseven 02-15-2015 06:15 AM
TURBO... suggest you speak with George at GP Autowerks. He's in Miami. Specializes in Porsche. 305-267-0516 (He's oldschool... no website.)
turbotoo 02-15-2015 06:17 AM
Ok. ˆll look into in tomorrow. Thanks.
