-   -   putting my 3.8 back together. (http://forums.pelicanparts.com/911-engine-rebuilding-forum/851228-putting-my-3-8-back-together.html)
scootergt3 02-11-2015 03:18 PM
I just replaced the bearings, rings and all new seals in my 3.8 rsr motor. thought I'd share a few pics.
The motor is from my 914 track car. 12.5:1 comp. twin plug, endurance RSR size valves, Web Cam 171/149, cams(center drilled), carrillo rods, ITB's with motec efi and more.
http://forums.pelicanparts.com/uploa...1423696588.jpg
http://forums.pelicanparts.com/uploa...1423696602.jpg
http://forums.pelicanparts.com/uploa...1423696611.jpg
http://forums.pelicanparts.com/uploa...1423696620.jpg
http://forums.pelicanparts.com/uploa...1423696632.jpg
http://forums.pelicanparts.com/uploa...1423696652.jpg
http://forums.pelicanparts.com/uploa...1423696673.jpg
http://forums.pelicanparts.com/uploa...1423696695.jpg
http://forums.pelicanparts.com/uploa...1423696719.jpg
txhokie4life 02-12-2015 11:11 AM
Looks sweet!
That's got to be a beast in a 914!
What are you putting to the wheels?
Mike
scootergt3 02-12-2015 12:15 PM
motor
Hp should be around 380-400 car weights 1,920 pounds.http://forums.pelicanparts.com/uploa...1423772089.jpg
http://forums.pelicanparts.com/uploa...1423772114.jpg
Pellesin 02-14-2015 02:49 AM
Hey man!
Cool engine! What part number crank case do you have?
Best regards
Per-Stian
scootergt3 02-14-2015 05:06 AM
964 rsr case. m64/04
Discseven 02-15-2015 10:13 AM
SCOOTER... nice work. Seen a few 914-6s... yours is tops. Clean set up... very nice. 3.8 in that weight is g-force terrific. Compliments.
Looking at your config brings back very fond memories. Worked on a rear end mod for a 14-6 with a similar high wing like yours some years ago. Using your 6 as base, it looked like this (below.) I know some like visual mods and others are offended. If offending, I'll delete.
http://forums.pelicanparts.com/uploa...1424023615.jpg
scootergt3 02-15-2015 05:06 PM
No offence taken. looks good! Yeah the HP to weight is crazy. I just did a full engine rebuild, tranny and suspension. I also installed new seats, fire system,all new brakes, al new oil and fuel lines and wevo shifter. I should be good for a few more years...
porschetub 02-16-2015 12:50 AM
Originally Posted by scootergt3 (Post 8483998)
Always loved this car and a bit famous,was an Excellence feature car years ago,remember it was built on a heafty budget,very nice.
scootergt3 02-16-2015 06:31 AM
Yeah, I bought it a few years ago. I have the excellence issue from Nov. 2002 I contacted the original owner last year just to touch base.... Nice Guy!
The car only has about 137 hours since the build in 2001.. I just figured i'd freshen up everything this winter and hit the ground rolling this spring.
Germanblood 02-18-2015 05:43 PM
Where do I buy one? The highly molested 914 doesn't get enough cred. What's it like to drive this thing? Please use as many analogs to lawn tools as you can.
bob barnes 03-10-2015 05:45 PM
Nice looking Engine but those Rods I believe are pauters not Carrillo's from the looks of things.
bob
