-   -   Aircon (http://forums.pelicanparts.com/911-engine-rebuilding-forum/852427-aircon.html)
dpetteng 02-19-2015 10:59 AM
Aircon
So I bought an engine with aircon compressor installed. is it easy to remove this and do I have to change anything else apart from the drive pulley?
can't use the aircon on the VW Bus it's going into!
brighton911 02-19-2015 04:15 PM
Sounds like you don't have to worry about evacuating any refrigerant so removal is as simple as Take out the bolts and you're done. Unless you have a clearance issue, no good reason to change out the pulley. The (sleeper) bus will surprise a few people!
dpetteng 02-20-2015 05:01 AM
Fantastic thanks. Didn't know if I was over simplifying things!
yes, should be a cool sleeper bus. Just need to get the suspension and brakes to the same level as the engine! Thinking of 986 brakes all round.
