-   -   Measured deck height today (http://forums.pelicanparts.com/911-engine-rebuilding-forum/852906-measured-deck-height-today.html)
Jcslocum 02-22-2015 11:22 AM
I got the deck height measured today using just a caliper on the edge of the piston and then using gauging wax (what I've used on the past on my Ducati engines) Sample info here:
cam degreeing and cylinder squish
And came up with an averaged height of 1.2mm I went here to enter all info to calculate the compression ratio:
Engine Compression Ratio (CR) Calculator
http://i70.photobucket.com/albums/i1...ps3d10972b.jpg
With the piston info on the JE website for these 10.5:1 pistons (I don't have the original paperwork), I get a CR of 9.84. This is with a .25mm shim under the cylinder. With all of the discussions in other threads about quality of gasoline and twin plug, 9.8 seems like a nice safe CR to have on this engine.
3.4, twin plug, JE pistons
