-   -   Early 911 question (http://forums.pelicanparts.com/911-engine-rebuilding-forum/853372-early-911-question.html)
Sperryfish 02-24-2015 06:04 PM
Early 911 question
I have located/isolated an oil leak on my 1971 911T that appears to be where the Driver Side Cam Chain Housing bolts onto the block. I was wondering if it's possible to remove the driver side cam chain housing without removing the engine..
Thanks...
Steve@Rennsport 02-24-2015 10:31 PM
Yes, its possible, but darned clumsy since the muffler, rear sheet metal, cam sprocket, idler, and tensioner all have to removed to get the chain housing off the engine case.
Naturally, you will need to re-time the cam when you are done.
Sperryfish 02-25-2015 06:08 AM
Sounds fun.. Cam Timing will require some reading before attempting..
Thanks...
Sperryfish 02-25-2015 06:10 AM
BTW, Muffler, Heat Exchangers already off to attempt to locate the cause of the major oil leak..
Aurel 02-25-2015 04:37 PM
I would do partial drop to get more clearance.
Scheebs 02-25-2015 07:22 PM
If you remove the 2 bumper guards, then the panel behind the license plate (not really a hard job at all) you will have plenty of room to perform this task. Especially since muffler is already off.
Sperryfish 03-01-2015 09:51 AM
It's 20 degrees in my shop so I'll start this project next week.. Thanks for the help..
