irobertson's Avatar
Shifted cylinder base gasket
While taking the 911 down off the lift today to bring in our new Golf and finish the required brake work, I noticed a little oil drop at the bottom of the motor.
When I put her back up in the air, I took a closer look and much to my dismay I discovered that the cylinder base gasket on #1 is protruding out of position.
Damn it! This is not going to be an easy fix :-(
Any advice is appreciated.
'88 sunroof delete Coupe in Venetian Blue (back on the road Wooo!)
'11 Cayenne Manual, as in it has a clutch :-) (daily driver)
'97 BMW Z3 (wife's ride)
Old 12-13-2014, 06:14 PM
The first thing I'd do is check the integrity of the head studs as lack of correct cylinder head torque can lead to base gasket shifting.
In any case, the fix requires removal of the heads/cam housings, and cylinder(s) to gain access to that part.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 12-13-2014, 09:36 PM
irobertson's Avatar
Thanks Steve.
It will be a while before I can get to this, but I will report back with the findings.
Old 12-14-2014, 08:41 AM
Originally Posted by irobertson View Post
Thanks Steve.
If you have ARP head studs, you may find loose head nuts and thats common.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 12-14-2014, 08:43 AM
base gaskets
I have had the coated ones squeeze out. One event on my track car. Not fun!!!
Still one place to go.
Old 12-14-2014, 07:09 PM
irobertson's Avatar
Mine are coated as well.
That's what came in the Wrightwood kit I bought.
Old 12-14-2014, 07:38 PM
No troubles with those gaskets for 25+ years and we've used a LOT of them.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 12-15-2014, 12:33 AM
irobertson's Avatar
Well the weather is finally warming up here in the Great White North, and I have a weekend to myself.
Today I attempted a shortcut fix for the shifted base gasket.
I pulled the valve covers, cat and left heat exchanger off, then proceeded to check the head stud torques. Cyl 2 & 3 were snug, but Cyl 1 needed about 10 degrees of rotation to get to the ARP spec of 38 ft/lb.
Then I backed all the studs off except for the front two on Cyl 3.
This took the tension off enough for me to gently tap the gasket back into place with a small wooden dowel.
I''ve now re-torqued all the head studs back to spec.
Now to check the stud torque on Cyls 4,5 & 6.
Replacement oil is due early next week, so I will have to wait to see if the fix was successful.
Old 03-14-2015, 12:57 PM
Since you have ARP heads studs, I would STRONGLY recommend checking them frequently.
We don't use them (and Raceware) for this very reason.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 03-14-2015, 02:09 PM
irobertson's Avatar
Thanks for the advice Steve.
Cyls 4,5 & 6 were OK.
The only one that was not to spec was #1.
Go figure.
Old 03-14-2015, 04:46 PM
Steve what studs do you recommend?
Old 03-15-2015, 07:13 AM
993TT ones, ONLY. Not cheap, but you really get what you pay for.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 03-15-2015, 11:04 AM
