964 cranck/pulse sender 91160621702 ?all equal?
hi/ciao
please the sender 91160621702 are same all? n. 91160621702 for 964 <90after n. 91160621703 >90 i look sstitution whit same for 996 (BOSCH) ??? the question is: all sensor 964 or 993 fit? i have engine M01 1989 (whiout gaskets heads...) THANKS grazie!
---the difference between insanity and genius is success-- Last edited by dan67; 03-19-2015 at 08:20 AM.. |
.the sensors were upgraded to at least 996 part numbers. The problem being the connectors were changed. There is 3 wires and no instruction on the color lay out that I can find. I'm not cutting any 964 harness with 1 chance in 6 of getting the wires correct.
So we keep running the old sensor. Bruce |
