-   -   Need help to ID this (http://forums.pelicanparts.com/911-engine-rebuilding-forum/857002-need-help-id.html)
Amstaff 03-21-2015 08:55 AM
Finishing up my 3.0 engine rebuild and as I go through my leftover stuff I find this. Any idea where is goes?
Hopefully you can see in the pix that it is threaded in the middle of it and has a shoulder that protrudes under the nut
http://forums.pelicanparts.com/uploa...1426953217.jpg
http://forums.pelicanparts.com/uploa...1426953243.jpg
http://forums.pelicanparts.com/uploa...1426953268.jpg
Amstaff 03-21-2015 09:02 AM
FYI
It is a 17mm
turbo nut 03-21-2015 09:10 AM
IIRC some where on AC bracket
Jcslocum 03-21-2015 10:10 AM
Engine mount thing that goes around the pulley or of the side of the cam chain case (right side) top back corner.
Amstaff 03-21-2015 11:58 AM
I did eliminate the AC bracket so tht was probably it.
Thanks,
Jcslocum 03-21-2015 02:25 PM
Here is where it goes:
http://i70.photobucket.com/albums/i1...ps2iozq8sr.jpg
http://i70.photobucket.com/albums/i1...psarkbny7x.jpg
