Where do 6 copper washers go?
Hi guys with my rebuild kit for the 930 there are six copper washers anyone know where they go? Thank you
Erick |
Lots of possibility...
What is the size: X x Y x Z in mm X: Inside Y: Outside Z: Thickness |
Will measure Tomorow. But they are the only cooper washers that came in the rebuilt gasket set . All others are aluminium
Thanks |
Under the injectors.
Bruce |
Oh yes. Thanks I am so far off I forgot
Thanks |
Yup, and those skinny little 930 CIS injector copper washers are not easy to find. You can probably reuse the old ones if they aren't squished.
Put a drop of motor oil on the injector threads when installing them and don't over tighten them. |
| All times are GMT -8. The time now is 03:46 PM. |
