gtc gtc is offline
abides.
gtc's Avatar
Cam Gear Flange doesn't fit
I'm installing some 964 cams in my 3.2, and having trouble with the left side cam gear flange. It is a tight fit, and will not slide over the end of the cam. (The right cam is fine, and swapping flanges makes no difference)
Is there a good way to get these to fit? Should i just take some emery cloth to the inside surface of the flange?
And I presume I may need to remove the flange to adjust the sprocket alignment, so it shouldn't be extremely tight, correct?
Graham
1984 Carrera Targa
Old 03-30-2015, 10:49 AM
Yes, I have a pair of 964 that are aftermarket billets an I have to take them in to polish down to slide the backing gear on and off.
When I opened the engine I had to use fire to expand and slide off.
Bruce
Old 03-30-2015, 11:11 AM
gtc gtc is offline
abides.
gtc's Avatar
I guess i'll have to measure and see what the difference in diameter between the left and right cam is. I have the thrust plates on, so I'd rather not pull the cam out (the Curil T will be a PITA to clean up), but i suppose that might be the best thing to do.
Graham
1984 Carrera Targa
Old 03-31-2015, 11:24 AM
