964 rebuild--which parts should I take to get soda blasted?
Im taking my case halves and transmission in to get soda blasted next week. Any other parts I should have taken in (looking for suggestions) Thanks
Depends on how far you want to go....if you read through my rebuild thread, you'll see that I've done everything apart from crankcase halves and 'box (I vapour blasted my pieces), and either left in the vapour blasted finish (e.g. intake manifold) or powder coated.
Tinware Valve covers Chain covers Chain boxes Cooling fan Cooling fan housing AC pump bracket Power steering pump bracket Some of the cooling shroud pipework.... I didn't soda/vapour blast the case halves or the gearbox, instead spending days of my life cleaning them manually....appreciate soda should dissolve, but the vapour blasting media that was used for my parts doesn't, so didn't want to risk not being able to flush all of it out again. |
Thanks I found a good list in Wayne's rebuild book too much appreciated.
Inside the valve covers...
Bruce |
what do I need to remove before I have the case halves soda blasted? can all the head studs be installed still? anything else I need to remove before going in the blaster? thanks
| All times are GMT -8. The time now is 11:51 AM. |
