-   -   930 turbo engine compartment seal (http://forums.pelicanparts.com/911-engine-rebuilding-forum/859462-930-turbo-engine-compartment-seal.html)
fredmeister 04-06-2015 11:54 AM
I am looking to replace the rubber seal above the turbo that seals the engine tin to the car body Part # 930-504-170-01-M136 ---cost is $120 or so. It seems like the 911SC uses a different part number that's half the price.
Question: can I use the 911SC seal in place of the turbo seal? I only need the section of the seal directly above the turbo as the replacement long seal also contains both edges that run along the valve covers which are fine on my car and I could trim them off the new part as I don't need to replace these.
What makes the turbo seal different?
thanks guys,
Fred
Henry Schmidt 04-06-2015 05:53 PM
thanks guys,
Fred
It's been a while since I put a turbo engine seal in but if I remember correctly, the turbo front seal is cut away to create clearance for the air pump and belt. The SC seal can be trimmed to work just fine.
