930-03 stamped engine
Hello,
I have a 1979 engine in my '81 sc, but I don't seem to be able to get a lot of information on it. I believe it is a ROW engine. Does it have the same power as the u.s. engine? Thanks |
Displacement 2993
max hp/rpm 180/5500 max torque/rpm 265/4200 bore/stroke 95/70.4 comp ratio 8:5:1 valves int/ex 49/41.5 ports int/ex 39/35 fuel system cis fuel inj engine serial # 6390001 notes RoW other than torque USA is 245/4200 engine serial# for USA is 6290001 Hopefully this helps |
Thanks for your help Scott
Thanks Scott, very helpful!
Keith |
| All times are GMT -8. The time now is 10:27 PM. |
