-   -   Sweeten it up before it goes into the car (http://forums.pelicanparts.com/911-engine-rebuilding-forum/861015-sweeten-up-before-goes-into-car.html)
Flat6pac 04-16-2015 03:16 PM
That was the request.
It was quite a trip for the month.
Some. Pictures and explanation to follow
Thanks for looking at my post
Bruce
Arrival
http://forums.pelicanparts.com/uploa...1429221997.jpg
Oil seepage on the main galley
http://forums.pelicanparts.com/uploa...1429222102.jpg
Disassembly
http://forums.pelicanparts.com/uploa...1429222372.jpg
Aftermarket cams w it ha nice street grind
http://forums.pelicanparts.com/uploa...1429222520.jpg
Flat6pac 04-16-2015 03:22 PM
More pictures
Pictures of the Alucil cylinders, virtually all streaked
[img]http://forums.pelicanparts.com/uploads24/image1429222721.jpg[/img
You can see them numbered
http://forums.pelicanparts.com/uploa...1429222882.jpg
PO said it did smoke
http://forums.pelicanparts.com/uploa...1429222947.jpg
Flat6pac 04-16-2015 03:33 PM
More pictures
All the up loads didn't take
#3
http://forums.pelicanparts.com/uploa...1429223240.jpg
http://forums.pelicanparts.com/uploa...1429223288.jpg
The rod says its 10 O'clock
http://forums.pelicanparts.com/uploa...1429223486.jpg
Second thought, maybe 9 o'clock
http://forums.pelicanparts.com/uploa...1429223556.jpg
Flat6pac 04-16-2015 06:21 PM
Someone has been in it before
You can see the 574 sealant around the studs and on the seal of the #8 bearing
http://forums.pelicanparts.com/uploa...1429233412.jpg
#8. Bearing with sealant
http://forums.pelicanparts.com/uploa...1429233475.jpg
All bearings were factory numbered
http://forums.pelicanparts.com/uploa...1429233686.jpg
Flat6pac 04-16-2015 06:30 PM
Cleaning parts and pressure check oil cooler
Got to enjoy the tool quality, Stomski Racing oil cooler pressure tester
http://forums.pelicanparts.com/uploa...1429234042.jpg
http://forums.pelicanparts.com/uploa...1429234095.jpg
http://forums.pelicanparts.com/uploa...1429234208.jpg
KTL 04-17-2015 08:56 AM
Nice job, as always, Bruce. Shame to see an engine that's so clean inside (must have used good oil and changed frequently) and has great looking main bearings but messed up cylinders.
Great use of the muffin tin too http://forums.pelicanparts.com/support/smileys/clap.gif I will add that one to my list of garage tricks for sure!!!
How many broken head studs, three?
Flat6pac 04-17-2015 12:01 PM
Case cleaned
Safety Kleen then pressure wash with super clean gets the nooks and crannies http://forums.pelicanparts.com/uploa...1429296944.jpg
http://forums.pelicanparts.com/uploa...1429296980.jpg
Heads are back. New exhaust valves, 12 guides, it was a smoking engine
I figured the wasted cylinders was the problem, turned out everything was.
http://forums.pelicanparts.com/uploa...1429297056.jpg
http://forums.pelicanparts.com/uploa...1429297127.jpg
mepstein 04-18-2015 05:45 PM
Michael's engine? I told him it's in good hands. :)
Flat6pac 04-19-2015 01:57 PM
Got to love the 574
I prefer to subassembly as much as I can before assembly including setting the valves when building up the heads.
http://forums.pelicanparts.com/uploa...1429476904.jpg
http://forums.pelicanparts.com/uploa...1429476954.jpg
http://forums.pelicanparts.com/uploa...1429477011.jpg
Flat6pac 04-19-2015 02:10 PM
Crank buildup using the Clevite rod bearings
Crank is polished and flowed because of the #3 bearing being a concern.
http://forums.pelicanparts.com/uploa...1429477715.jpg
http://forums.pelicanparts.com/uploa...1429477759.jpg
http://forums.pelicanparts.com/uploa...1429477798.jpg
Flat6pac 04-19-2015 02:19 PM
Layout the bottom end
http://forums.pelicanparts.com/uploa...1429478123.jpg
Still needs 574 on seal flanges
http://forums.pelicanparts.com/uploa...1429478342.jpg
Flat6pac 04-20-2015 07:43 AM
Assembly
I install the bottom studs after the pistons are in place. It gives my hands more room for inserting the pin clips.http://forums.pelicanparts.com/uploa...1429540772.jpg
New rings on a choice set of Mahle P&Cs
http://forums.pelicanparts.com/uploa...1429540860.jpg
With new studs installed
http://forums.pelicanparts.com/uploa...1429541010.jpg
Flat6pac 04-22-2015 12:32 PM
Heads install and finishing the long block
http://forums.pelicanparts.com/uploa...1429730480.jpg
http://forums.pelicanparts.com/uploa...1429730607.jpg
http://forums.pelicanparts.com/uploa...1429730652.jpg
http://forums.pelicanparts.com/uploa...1429730695.jpg
http://forums.pelicanparts.com/uploa...1429730790.jpg
The last post on this build as it was only for the long block.
Next long block will be a 3.0, I'm considering a crank drive for a 3 prong CD so it can install in mid year car more easily
Bruce
KTL 04-22-2015 12:38 PM
Nice job as always Bruce. What's the black coloring on the cylinders' exterior?
Flat6pac 04-22-2015 04:21 PM
Just the nature of the Mahle cylinder I guess and I didn't clean them in chemicals as there was no oil or sediment on them. I just ran safety Kleen while I was using the scotch bride on the Nikisil inside.
Bruce
KTL 04-23-2015 12:23 PM
Ok that's weird on the cyls. I've got a set of '85 3.2 Mahle cyls that are bright aluminum. The alusil cyls on my former '87 were dull gray but not blackish like that.
So I thought yours might have been coated with something like this stuff
BBE Heat Emitting Coating | Swain Tech Coatings | Industrial Coatings | High Performance Racing Coatings
Flat6pac 04-23-2015 01:16 PM
Not that I know of, they were just dark. The history of the car was good, a major dealer had it but when we got it on the lift and some window cleaner there was cold pipes.
The top end rebuild showed several severely burned valves. The cams showed the rockers riding the back of the cam because valve lash was too tight
Bruce
KTL 04-23-2015 02:16 PM
Riding the back of the cam, meaning since the lash was too tight the rocker pad would ride on the "uphill" side of the base circle where one would expect little to no follower contact since the valve should be closed?
Speaking of burned valves, it made me think of a friend's valve guide I recently saw. '87 3.2 with 170K that doesn't use hardly any oil (surprising) & had a previous top end around 2000 with 100K on the clock. So I would guess this picture is a case of the guide being starved of oil from stem seals that do too good of a job sealing the stem? Sorry to hijack but just thought i'd ask your opinion.
http://forums.pelicanparts.com/uploa...1429823679.jpg
Flat6pac 04-23-2015 03:54 PM
The white Teflon seals do too good a job of sealing. I can remember the suggestion was to use the white ones in combination with the brown but the machine shop said throw out the white ones.
As I recall there was 4 or 5 burned like in the picture. The owner keeps them on his office desk because it was so unusual.
Bruce
KTL 04-23-2015 05:44 PM
Thanks for the info. The guide I pictured was sealed by a Teflon seal
