em78911's Avatar
1984 Euro 3.2 P&Cs on a 1978 3.0?
Hi all,
What else wold be required or needed for this be done? I believe the bore is the same. Sorry if this a basically asked complex question. i have a buddy who will provide me the Euro 3.2 P&Cs I just want to know if it can be done and what all would be needed to make this a viable option. vs rebuilding my 3.0 back to stock as I had planned. Thanks for any and all input.
Eric
Old 07-29-2015, 06:04 PM
3 restos WIP = psycho
kenikh's Avatar
SC has a 70.4mm stroke cranks vs. the 74.4mm crank of the Carrera. You'll lose a lot of compression unless you also swap the crank
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 07-29-2015, 06:31 PM
SCadaddle's Avatar
Con Rod Bushings
Old 07-29-2015, 07:11 PM
non-whiner
mreid's Avatar
Buy Pistons with the pin placement for a 3.0. Since you are this deep in, change the cams to get full value and you'll want new Pistons anyway for valve clearance. BTW, this setup is still a 3.0.
"Too much is just enough."
Old 07-29-2015, 07:38 PM
em78911's Avatar
thanks guys.. I think i'll just pass on them.
Old 07-30-2015, 08:13 PM
