-   -   frest engine where can this leak come from? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/863510-frest-engine-where-can-leak-come.html)
ertech 05-02-2015 04:54 PM
Hi guys
just installed newly rebuilt engine with writewood racing gaskets
I have a leak by one of the nuts of the oil cooler not the part on the bottom where in it rounded?
can this come from the seal?
bolts are tight
thanks
for your help
Erick
http://forums.pelicanparts.com/uploa...1430610833.jpg
Henry Schmidt 05-02-2015 05:10 PM
Picture is too low quality to tell.
Can you help with a larger one?
ertech 05-02-2015 06:30 PM
Thanks Henry
here is a better picture I hope ,that's all I have
it the facing the back of the car
boyt911sc 05-02-2015 07:13 PM
Try again.......
Originally Posted by ertech (Post 8605536)
Thanks Henry
Can't see the picture. Too small for the naked eye. Try again and make it visible. Preview post before submitting. Good luck.
Tony
ertech 05-02-2015 07:31 PM
sorry here it is at the nut not the round part
thanks
http://forums.pelicanparts.com/uploa...1430620201.jpg
fanaudical 05-02-2015 08:08 PM
I suppose that possibly from one of the upper seals. Did you have the cooler cleaned/pressure tested prior to start-up? I had mine fail on one of the fins close to the base of the cooler - initially thought it was a seal.
ertech 05-03-2015 04:07 AM
Yes I have it cleaned and pressure tested it was done by a company in California that does ultrasonic cleaning
mreid 05-03-2015 05:20 AM
That looks like an oil cooler seal leak. However, take a fresh, white paper towel and with the engine cool reach around the intake and dab the towel all around the breather, oil temp/pressure sender area (triangle of death) and then inspect the towel. Any fresh oil on the towel may indicate this is your problem and it in running down the front of the engine by the cooler (typically how the TOD leaks show up).
ertech 05-03-2015 11:14 AM
YES YES YES SO HAPPY
Was the oil switch for some reason was not tight enough
Stay tuned more leaks to solve
manbridge 74 05-03-2015 11:38 AM
What's up with all the epoxy to left of cooler in pic?
ertech 05-03-2015 12:06 PM
On late 80's block There is a place where époxy is needed There is some sort of tube that goes through the casing
Flat6pac 05-03-2015 02:49 PM
And it's on the inside area too under the cooler opposite where the JB weld is in the picture
Bruce
