-   -   Camshaft install question (http://forums.pelicanparts.com/911-engine-rebuilding-forum/863551-camshaft-install-question.html)
michael lang 05-03-2015 03:55 AM
As noted in my rebuild thread one of the main changes I'm doing is installing 964 cams.
After I put the cams in, I noticed the left side was a little inset in the cam tower as compared to the right side where it went flush up against the very end of the carrier. I mentioned this to a tech and he told me that he has run into this before on some of his work and that I really didn't need to give it to much thought at that time as it would not matter because the sprockets have not been installed yet. So I didn't. Now that I have the thrust plate on and the spacers in, there is still some movement of the cam in & out of the tower.
I put everything back exactly like it came apart, 1 big spacer 5 small spacers. Even with the woodruff key installed as far in as I can get it the cam still has some jiggling in & out.
I don't know if it's supposed to be like that but if it is not, is my best fix option to get a couple more spacers to get rid of the gap?
Also, is there a more efficient way of installing the woodruff key? I taped up the ends of some Channel Locks and squeezed the hell out of them to press the key into the cam but I can't be sure if it went all the way into the cam end.
Thanks in advance.
