-   -   2.4 cam timing question (http://forums.pelicanparts.com/911-engine-rebuilding-forum/864157-2-4-cam-timing-question.html)
Amstaff 05-06-2015 05:52 PM
I pulled my 2.2 that was converted to a 2.4 and replaced it with a fresh 3.0. My brother built the 2.4 and apparently he missed a few things while building this engine so I am going to take it down to the block but not split the case and reassemble it (I hope he doesn't read this!). The reason I am going to take it apart is that it has several leaks and I see red silicone between the cam housings and the block plus at least one of the chain ramps are on backwards and it has what looks like home made solid tensioner which I will replace.
This is what I know (have been told about the engine). It is a 2.2 that has been stroked to a 2.4. It has S heads (can see the part number), I am told it has 10.5 compression, and S cams (the end of the cams have an S and a dot on them).
My question is, when I reassemble it what should I set the cam timing to?
Flat6pac 05-07-2015 03:17 AM
Set the cams to "S" spec then check clearance to the piston.
Bruce
Amstaff 05-07-2015 03:18 AM
What is spec?
bgyglfr 05-08-2015 01:55 AM
Get Wayne's engine rebuild book. It has the specs and instructions on how to set the timing. You will also need a dial gauge.
Amstaff 05-08-2015 04:20 AM
I have the book. I guess I need to look at it again.
Amstaff 05-08-2015 08:26 AM
Found it... 5.2
