Possible to use two different case halves
Is it possible to use two different 3.0 case halves on a rebuild.One of mine is damaged
It is possible.
You will need a good method to measure main bearing journals for ovality and well a intermediate shaft journals. The cylinder base deck will need to be checked as well. A qualified Porsche machinist can correct any inconsistencies that may exist. |
Thanks Henry.
I still might ship that other case to you if your still up for it?
| All times are GMT -8. The time now is 03:36 AM. |
