-   -   71 t engine info needed (http://forums.pelicanparts.com/911-engine-rebuilding-forum/866019-71-t-engine-info-needed.html)
82 sportsc 05-19-2015 01:29 PM
original engine is 6116184 and vin is 911 110 0966 so end of the 71 run . So is engine 2.2 or understand they started 2.4 at end of run.
Thanks for info and were list is posted for engines.
Frank
Henry Schmidt 05-19-2015 01:31 PM
2.2
Easiest way to tell:
2.0 and 2.2 cranks have two drill holes for oiling.
http://forums.pelicanparts.com/uploa...1432069007.jpg
2.4-2.7 have only one.
http://forums.pelicanparts.com/uploa...1432069043.jpg
Of course this requires that you remove the flywheel to tell.
