-   -   I.D. part (http://forums.pelicanparts.com/911-engine-rebuilding-forum/866045-i-d-part.html)
tcramer 05-19-2015 06:29 PM
I.D. part
hi guys,need help with this part.It goes on my '69 2.0 at the end of the air channel on the shroud.It's a piece of sheet metal about 5.5" x 3.5" x 1mm thk. With a right angle bend along its length 1/2" wide. It was riveted on with 3 rivets.I know it goes on right above the oil cooler but I can't figure out the orientation.Any help greatly appreciated.thanks,T.C.:confused::confused:
Heinz911 05-20-2015 01:22 AM
The piece should line up with the edge of the oil-cooler right next to the nr.6 cylinder. I think the bended edge then is pointing in the direction of the rear of the car. This picture I found on Ebay. The metal is bended but you can see the orientation of the edge.
http://i.ebayimg.com/00/s/MTIwMFgxNj...Sfsty/$_57.JPG
tcramer 05-20-2015 09:38 AM
Thank you so much Heinz911!
