Trick question
Hello to all honorable forum.
i have a trick question ......my case is *6403090* and i have the craziest idea can i fit 107 mm liners and turbo piston from 993? will it fit? do i need to change the heads as well?will it work with 930 single turbo headers? please say and write all you think of give me all of your knowledge THX |
Cylinders..........
I would give the guys at LN Engineering a call. They can tell you what can be made to fit and what can't. I know that they make slip fit 100mm cylinders for the 3.0 and 3.2 liter blocks. I think that everything from 102mm and up requires machining the spigots in the block. Good luck building your monster motor!
6403090 would be a 914-6 case. So, unless you have a typo, I'm going to say no
chance. |
If a 914-6 case (basically same as the T), not a chance. 93mm is as wide as you can go. The 3.0 cases have a wider stud spacing, which allows the spigot to be wider, which allows wider cylinders.
| All times are GMT -8. The time now is 10:11 PM. |
