getting a slight rap @3k RPM under light throttle
Just got my car running after the engine sat dormant for 5 years and the chassis for 20+.
It's a 3.4 EFI 930 with hydraulic tensioners. I am getting a rap from 2800-3200 RPM with very light throttle. I am leaning towards tensioners. There is no sound on decel nor under moderate and above acceleration. http://youtu.be/evHQkl6Q1IE http://youtu.be/pu4xxKKPG7g I'd like to get this sorted out soon so I can get it to the dyno. I am running 15/40 Rotella and seeing 2.5 BAR for oil pressure @3k. This noise is less noticeable when the car is cold. Think 20/50 will fix this issue? I am getting ready to do an oil dump when I get back. Plan was to run the car for a tank of fuel to get all the residual fuel out and then dump oil and do filter changes. Fuel, oil and oil screen (pre filter) change. |
pressure per gauge does seem a bit low vs. rpm. You might want to verify the gauge and/or sender is operating correctly.
| All times are GMT -8. The time now is 11:07 AM. |
