Please confirm Cam location stock 1975 911.
I just want a confirmation from the experts that I installed the cams on the correct side of the engine before I start the cam timing.
So, where should the 911 105 143 00 cam go? Driver side or passenger side? Thanks, |
Dave. The right cam has the lobes paired together. Each pair look like a rabbit ears.
143 is left cam shaft Bruce |
Thanks Bruce.
What do you set the cams at? I checked Wayne's engine book and there is no reference in the book I have. It is a 2003 printing. |
.4 to .54 with .5 the preferred
Bruce |
Cam shaft installation........
Dave, Look at Wayne's book Chapter 6 and refer to figure 6-5. The illustration demonstrates the cam shaft profiles for left and right side. Bruce A. is an excellent source of information. PM me if you need his tel.#. Tony |
| All times are GMT -8. The time now is 03:37 AM. |
