Oil lines
Could use some help, I have the engine out of my car and was looking at the oil lines. The hard parts look fine, the rubber line sections need replaced. Anybody know of someone that can replace the rubber line and Ferrells so I don't have to spend over $400 on new ones.
Yeah there's a guy on this forum called Len Cummings who makes replacement lines; I've only seen him post about fuel lines, but I'm sure if you PM'd him, he'd be able to help. Can't remember his username, but easily searchable
Found this thread as a starter-for-ten for you... The trouble with the oil lines is that a lot of them are pre-formed/shaped to fit between the tank, through the inner wing aperture and then place the hose in the correct location engine-side...now, whether he can help with that part, I'm not so sure....FWIW, I ended up buying all new genuine Porsche hoses from the tank, and making my own custom lines up for things like the oil return line from engine > tank return line. I've spent an absolute fortune on plumbing in general on this build, but in-for-a-penny and all that.....can't risk any of them letting go. |
BoxsterGT... Check this link:http://forums.pelicanparts.com/porsche-911-technical-forum/816679-im-trying-contact-boxter-gt.html
When I wanted to do this I took the pieces to my local hydraulic repair shop. They brazed on different ribbed/grippy ends, which fit the hose sizes they had, and crimped those on. I made sure that where the two ends needed to be in the proper orientation to each other, that they knew that and made sure they came out that way. All in all, worked great, and a lot less expensive than buying a whole new set. They have held up well over quite a number of years now.
4-#6 and 4-#8 beadlock A/C hose fittings, 2 feet of 3/8 line and 1 foot of 5/16 line and someone who can crimp above the flare on the old hose barb. Can't really be that hard, can it? |
| All times are GMT -8. The time now is 03:06 PM. |
