1980 sc stock cams
new to the forum, i am in the middle of rebuild of stock 1980 sc 3.0, in waynes rebuild book he lists 2 different sets of cams for 1980 sc, with two different degrees of top dead center. how do i find out which set i have in my car. any help??
Old 07-02-2015, 07:30 PM
The cams are all the same from 78-89. The timing setting changed a couple of times. You have a small port engine so you should use 1.4 to 1.7mm.
-Andy
Old 07-02-2015, 10:50 PM
