-   -   Whining (http://forums.pelicanparts.com/911-engine-rebuilding-forum/871303-whining.html)
DSPTurtle 06-18-2015 10:22 PM
Whining
Real whining...
Have we had a good ***** fest about installing JE circlips lately? If not I'd like to whine about the three places I am currently bleeding from.
At least they're all home now...
http://forums.pelicanparts.com/uploa...1434691344.jpg
carrerarsr65 06-18-2015 11:02 PM
tool
I made a tool that worked great a piece of cheap mop handle cut on a slant on one end and I think I used a 13mm socket as a pusher ,load the clip ,push it home worked like a charmhttp://forums.pelicanparts.com/uploa...1434693598.jpg
http://forums.pelicanparts.com/uploa...1434693641.jpg
http://forums.pelicanparts.com/uploa...1434693689.jpg
the o,d, is critical it slip inside the piston/pin area
DSPTurtle 06-18-2015 11:40 PM
Very nice. I have one of those for the water-cooled stuff but not for our air-cooled builds. There's some kind of sick satisfaction once you get all six in...
Henry Schmidt 06-19-2015 05:43 AM
One of the truly great things about using Supertec head studs is the ability to install the studs after installing the cylinders.
This gives the builder unprecedented access to the wrist pin clips for easy, accurate installation.
No fighting with rings compressors around studs (pistons installed on the bench), reduce risk of a (Jesus) clip jumping into the engine and reduced time spent struggling altogether.
http://forums.pelicanparts.com/uploa...1434717540.jpg
Old dog new tricks? there really are no "new tricks" just experience.
DSPTurtle 06-19-2015 06:33 AM
Good point Henry. You probably saw that I had the bottom two Supertec studs out. Maybe on the next one I'll be so bold as to do it with no studs like in your pic.
Flat6pac 06-19-2015 06:54 AM
Studs out
I like to keep the bottom row out so my hands have room to use the Stompski circlip injector and I can use cylinder locks on the top studs.
Bruce
Henry Schmidt 06-19-2015 07:30 AM
Bruce
Once the cylinder is in place you can install one or more studs and then use your cylinder locks but this method won't work with conventional studs. It only works with Supertec type head studs.
Most others require a stud height measurement.
Try it. You'll be amazed at just how easy and precise piston/cylinder installation becomes.
This method also combats the struggle that you may encounter from "porcupine studs". A phenomenon where the case inserts are installed poorly leaving the head studs pointing in every direction.
