-   -   1985 3.4 build using MAF 279.56 HP, 237.63 RWHP (http://forums.pelicanparts.com/911-engine-rebuilding-forum/871561-1985-3-4-build-using-maf-279-56-hp-237-63-rwhp.html)
Geronimo 03-01-2019 02:14 PM
Just trying to get a sense of dollars to hp for my future rebuild.... without asking you to give exact costs, would this build be in the $20K-$25K range?
I kinda want to do a tougher N/A build on my SC, but boost is just so tempting.
911 tweaks 03-02-2019 03:32 AM
Great to see continued interest in this build...
Q: did a new cam get chosen and installed over that winter...??
Specs and results...?
I am very interested to know if a new cam was used and how it performed...!!
scarceller 03-02-2019 12:41 PM
Best cam was the DC21 results in this thread further up.
scarceller 03-02-2019 12:43 PM
Likely 25-30K range with twin plug and the MAF setup.
scarceller 03-02-2019 12:49 PM
Also, look at this single plug build I tuned, solid results for very basic simple 3.4L upgrade. You can now even do a 3.5L with 100mm cyls from LN Engineering that drop right into the case, no machine work required.
http://forums.pelicanparts.com/porsche-911-technical-forum/962997-1984-911-3-4-sleeper-hotrod-end.html
Geronimo 03-02-2019 02:26 PM
At that price point wouldn't a 3.6 swap be 10K cheaper for similar power?
clutch-monkey 03-03-2019 12:41 AM
check out catorce's thread for billet 3.6's^
Geronimo 03-03-2019 01:13 PM
Pretty sure that would break any budget before you start. lol
clutch-monkey 03-03-2019 01:43 PM
idk- any 3.6 is going to need a refresh while it's out. may as well start fresh and go billet haha
aircooledfan911 04-26-2019 05:33 PM
New adventures of this build.
At the St. Louis Concours d'Elegance. 2nd Place in the European Cars category. Behind a 1967 Austin Healey that would have been smoked on the expressway. The judges may not have realized that this is somewhat unusual 1985 Carrera with a pseudo-RS engine thanks to Terry and Sal.
http://forums.pelicanparts.com/uploa...1556328365.jpg
scarceller 04-27-2019 04:25 AM
Congrats on 2nd place! That's a super clean car with a real strong motor, it's a sleeper!
Enjoy it for years to come!
Bigtoe32067 05-04-2019 01:33 PM
Sal and/or Terry, if you guys still monitor this thread do you have a feel for what if any difference there would be if this engine had ITB's that were tuned properly?
I'm considering a similar build as this but with ITB's and wondered your opinions.
Thanks in advance
Tony
crashmy911 05-07-2019 04:21 PM
With itb's you would run high over lap cam and make more power.
aircooledfan911 06-22-2019 08:36 PM
Hopefully, if everything lines up, the car will return to Terry this winter for more “fiddling”. Stay tuned.
