break in oil change for fresh 930
I've read the various break in procedures and oils. My question is after the initial 20 min. @ 2,000 rpm with break in oil what oil do you switch to for the next 100-200 mi. of driving. How many miles using what mineral or synthetic oil and weight until I switch to the usual Swepco 20-50.
I am about to embark on the same here shortly. Fingers crossed for August..I am just going to use 20w 50 valvoline racing oil since it is high in Zinc.
20w 50. The turbo's bearing housing get's insanely hot so I think full synthetic oil is best for it. Especially after shutdown when oil flow stops.
I wouldn't switch to synthetic until I was pretty sure that the rings are seated. The initial 20 minutes at 2,000 is just to break in a new cam and rocker arms.
What do you use after the break in and before the synthetic, and for how many miles?
A good quality conventional oil with a bottle of Lucas engine break in additive to top it off.
after 20
before full break in and switch to synth Dello 400 15W40 |
| All times are GMT -8. The time now is 03:16 PM. |
