-   -   Hole size for vacuum port on an intake manifold (http://forums.pelicanparts.com/911-engine-rebuilding-forum/873865-hole-size-vacuum-port-intake-manifold.html)
Bird911 07-08-2015 06:52 AM
I have purchase a Jenvey ITB kit for my 3.4. The intake manifold is coming with bumps that needs to be drill and taped if you elect to use a vacuum port. I understand I will need to drill two holes; a smaller one that will go all the way through the manifold for the air to be sucked in, and a larger but shallow one that will be taped to screw the vacuum nipple.
My question is what size do the small hole needs to be ? The tip of the nipple is 1/8’’ I.D. but is this too big ? I got the nipples at my local hardware store as they seem to be the good size and I could not find any specially made for this application. Feel free to tell me if I’m not using the correct nipple.
http://forums.pelicanparts.com/uploa...1436363420.jpg
http://forums.pelicanparts.com/uploa...1436363459.jpg
Thanks,
Bird911 07-15-2015 08:43 AM
Anyone ?
SoyRacer 07-15-2015 09:00 AM
On the last ITB setup that I did we drilled 1/8 pilot holes and then drilled for the fitting. Being that they are tapered fittings I usually drill all the way through so that I can run the tap through. Tapped all six and ran the hoses to a manifold for a MAP sensor. Have also used it as a vac port for brake booster.
Bird911 07-17-2015 06:42 AM
Thanks SoyRacer. I will also use them for MAP sensor and brake booster.
MetalDoc 07-17-2015 06:59 AM
Jenvey vacuum port and fitting
I took the manifold down to the student machine shop and they drilled 3/16" holes for the ports, followed by drilling and tapping for the pipe threads. The engine is out of the car so I have no idea if this is the best solution. How are you going to connect the throttle linkage? I replaced the linkage in the tunnel with a cable.
Paulhttp://forums.pelicanparts.com/uploa...1437141501.jpg
http://forums.pelicanparts.com/uploa...1437141547.jpg
Bird911 07-17-2015 07:25 AM
Thanks Paul, I will try to do the same as you. Your tapped hole also seems to be 1/8 NPT, same as my nipple tread.
My engine is also out of the car, and I still don't know how I will connect to the throttle linkage. There was a cable included in the kit but it is way to short. I will need to think about this one.
Are these copper nuts on the intake studs ? any reasons to use these ?
MetalDoc 07-17-2015 07:43 AM
Hugo,
Most of the hardware store nuts are too big 14mm? I think these are 12mm which bolts down without hitting the manifold. I chose these nuts for the size. There is not too much torque on them so copper should work. I think these nuts are copper plated?
Here is a link to the cable install. My project has dragged on so I have not put the engine back in to connect the other end.
Paul
http://forums.pelicanparts.com/porsche-911-technical-forum/646216-sc-project-2.html
Bird911 07-17-2015 08:13 AM
Paul, Yes I remember seeing your thread. Great project, I am also going through all the same steps with my project.
This is another thread I found regarding the linkage replacement with a cable. I would like to go directly from the pedal to the ITBs.
http://forums.pelicanparts.com/porsche-911-technical-forum/309504-early-911-replacing-throttle-linkage-morse-cable.html
MetalDoc 07-17-2015 08:32 AM
Hugo,
I liked the Morse cable, but I couldn't figure out what length to get. Hopefully, the cable I have installed will work. The springs on the Jenvey are pretty stiff.
Paul
