Did I screw up my Valve Adjustment?
I did a valve adjust and switched from delo 15w40 to VR1 20w50. I had a detectable-only-by-me tick that was bugging me because I had never heard another 3.2 tick like that. Well, now its worse. This is my second valve adjustment and I really don't want to believe that I f***ed it up.
I only spent all day on this... ugh http://forums.pelicanparts.com/suppo...ys/rlwhore.gif https://youtu.be/r2HO2_kMMJ4 https://youtu.be/9eLH1EfY_9g https://youtu.be/bSscG8ZaP3o |
i can hear some stuff going on, its not terrible but i dont know what it sounded like before.
what i would do is switch to brad penn 20-50. get it on ebay. go back and redo the valve adjustment and have some spare feeler gauges. dont get hung up on the drag of the gauge when its between the valve stem and the rocker. remember the adjustment is .004 +-.002. so when youre going for the final adjustment make it tight, it sounds like your being careful which is good but make them good and tight and they will shut up. also what you could be hearing is worn valve guides, so after the tight adjustment there might be some clicking going on. that engine sounds good though i dont think you have anything to worry about |
VR1 is fine as long as you dont have a cat on the car.
did it get worse as soon as you were done or did it get worse over time. if it got worse as soon as you were done, do as above. as long as you can get the feeler in it is not too tight. you want some drag or for it to be tight fit. that is how you get them consistent. when doing it, do not losen the lock nut all the way. if lose- hold the adjuster and turn the nut just a little. turn both nut and adjuster CW using the angle of the slot as a gauge to how much it is turned. if tight- turn both CCW then hold the adjuster and tighten the nut. make small changes noting the angle of the slot. make 1/8 degree turns then check. when done rotate the crank several times and go back thru them. you dotn need to drain the oil. only a little will come out. |
I tightened them by leaving the gauge in while I tightened the adjusters. They were mainly too tight (could not get the feeler in). The loosen/tighten thing I figured out eventually. Pretty much what I did. I did a check run after with the gauge, had to adjust #5 an eight of a turn. The clapping seems to be coming from the drivers side though. I developed a valve guide hypothesis as well, since it is worse than before I would guess it is not the source of the noise??? |
You're better than me..I can't even hear it.
When you have a gap you will get a tick noise, setting valves tight will help reduce the noise, bad side is that when the valves and seats wear and they will, then the valves stay open. Not good when this happens, go 4 + 2 and Learn to like the tick, when it quits, you know it's time to run them again. |
I can hear it. One is a smidge loose or there's a bad elephants foot. Consider using a stethoscope to isolate and save time?
I know that .006 is "within tolerance", but are you saying that this is better than .002? |
Doublebuffle, I just went through this. Below is the thread with some video for comparison if the helps you. Your overhead video sounded good to me. The vid of the exhaust valves does sound a bit noisy, but I am no expert and that is why I asked for help on P. It is a lot of work I know, but if you are going to second guess yourself, you might be better off doing it again for your own piece of mind. Good luck.
http://forums.pelicanparts.com/porsche-911-technical-forum/873621-valve-engine-sound-what-do-you-think.html |
Big progress.
I did half of the valve adjust over again, only the six intake valves. Reasons for only those: 1. Harder than exhaust and mostly likely that i screwed them up. 2. The idea of spending a lot of time with the car half in the air was not appealing to me... (alone and very 'cautious' in my one car garage). It sounds much better, we are back to detectable-only-by-me tick which of course; could easily be the expected valve guide wear. The rockers are pretty tight. We are in "I can manage to get the feeler gauge in" territory. I imagine that engine builders probably do this by feeling the play in the rocker movement. You can almost tell by rocking them back and forth when it's "right". Ok, I can do videos if you want, let me know. EDIT: I plan on doing exhaust too. No need to waste the oil though. http://i.imgur.com/i5JiG.gif |
check out the backside method. I've done it twice on my car now with the engine in and twice with the engine out. It's really not that hard unless you have headers in the way.
Amazon.com: K-D Tools 161 Deluxe Feeler Gauge: Home Improvement Would this work? |
Put it in, snug it and lock it then move on. |
If you are doing the back side (Go/No-Go: Pelican Technical Article: 911 Valve Adjustment - The Backside Method), get the 12" version of the .0025 (Go, # PEL-LM-0025) and .003 (No-GO, # PEL-LM-003). If you are doing the normal, its the .004 that you have been using. |
I used this.
I have some tick coming from the drivers side bank, but nothing you wouldn't expect from an air cooled engine. It's a little tight to get on some of the studs on the bottom of the engine, but it gives you a "no guess" reading on the true gap. http://forums.pelicanparts.com/uploa...1436875574.jpg |
The feelers are the .0025 and .0030. I just bought a set of feelers at Autozone that had those two on it for about $6.00. I haven't had any trouble using the standard feelers to do the backside valve adjustment.
BTW, the set you asked about from Amazon would be fine. You don't need 12" feelers to do the backside adjustment. |
http://forums.pelicanparts.com/uploa...1441584375.jpg
Did another Valve adjust. Car now sounds great until fully warmed up. Tick remains when warmed up. |
It could be worn out bushings on a single rocker or two
Bruce |
I could not find a spec. on rocker play (in the axial direction). The was about 1mm movement on all of the exhaust rockers IIRC. I had to be careful to only "rock" them in the rotational direction. I ordered a real stethoscope, so I will be investigating further on Wednesday.
For the record, if you have a catalyst, it will be need to be removed for Cyl. 1 & 2 while using the Stomski tool. It is a breeze though... awesome. I was also happy to see that my "feel" for dragging the feeler blade had got me very close on most of the valves. Others though, were way off. Observing my last job (with the .004 gauge), I noticed that my tightest valve was .004". This should be useful information knowing that I -thought- I had a medium-high level of drag with the feeler. |
Really though it's not a huge deal... an "engine out" is planned for the winter to replace the aging fuel system. The "while you're in there" should be interesting to watch http://forums.pelicanparts.com/support/smileys/pc2.gif
d/dx Timing chain Fuel injectors Fan/alt rebuild Head machining Completion of A/C and CC delete surface rust repair of engine compartment sound pad replace etc... |
| All times are GMT -8. The time now is 12:28 PM. |
