MFX MFX is offline
Is this engine a 75 or 76???
Hi,
I just bought a rough mid year coupe with pulled head studs. I was told it was a 76 but checking the vin it is a 74. The engine has been replaced at some stage but I have done my research and I have conflicting numbers. The engine type is a 911/41 which by Wayne's book shows it to be a 75 engine, but the engine number is 6160048 which I gather should be a 76 number?? Anyone have some clarification on this?
Thanks.
Old 07-16-2015, 05:09 PM
Bird911's Avatar
You are correct, 911/41 was used in 75, and the third digit ''6'' in 6160048 mean this is a 76 serial number.
The only explanation I see is since you have an early serial number (0048), maybe the factory still have some unused blocks printed with 911/41 at the end of the '75 production, and decided to use them for the first production of '76 cars.
This is still very mysterious...
Hugo
Old 07-17-2015, 07:01 AM
MFX MFX is offline
That is kind of what I am thinking, but like you said it seems odd. If anyone else has some further insight into this it would be good to know.
Old 07-17-2015, 02:35 PM
djpateman's Avatar
type & serial # is correct for a 911 engine in Japan in 1976
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 11-30-2015, 07:30 AM
