Hodge-Podge 2.0L
I figured you guys here would be more knowledgeable about engine combinations than myself, so here's the info:
'68 2.0L 'L' motor. '69 'S' pistons Standard 66mm counterweighted crankshaft center-lube Solex cams stock air injection, small (tiny) valve heads. I originally purchased the motor as a fuel economy option for my 914 as my RS 2.7 sucks down gas like crazy, and I daily drive my 914. It spun freely, and it appears to be pretty clean on the inside, despite the grime buildup all over the outside of the engine. The 69S pistons were a nice surprise, as we're the solex cams, as I assumed it was just a stock 2.0 'L' motor. So far ever internal component has checked out to being well within spec, with the exception of severely worn valve guides. From a combination standpoint, what should I expect out of this engine? I know the valves in the heads are restrictive for the solex cams, but the valve size should keep port velocities up at least.. The main goal is to not spend money on big components. Rings, bearings, valve job, all will be done. It would be really nice not to dump money into cylinder heads though. So, what say the experts that know way more than myself? http://forums.pelicanparts.com/uploa...1437678232.jpg http://forums.pelicanparts.com/uploa...1437678306.jpg |
69
The pistons are probably worth half the value of the engine.
9.9 1 year only You need the heads to seal the cylinders, all sealing changed in 1970 Bruce |
If it were my engine, I'd install a set of later (2.2) heads on there, however thats not a cheap proposition. For best performance and some additional detonation insurance, thats the way to go.
