-   -   Cam shaft securing bar - 3 choices - much difference??? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/876485-cam-shaft-securing-bar-3-choices-much-difference.html)
haggis780 07-27-2015 11:54 AM
Just getting ready to order a camshaft securing bar for engine rebuild - 88 911. I see there are three choices offered from our host......is there really much of a difference between them apart from price point.
Porche OEM part 000-721-919-10 OEM $170
Cam Holding tool part 000-721-919-10 $120
Cam shaft securing bar part PEL TOL P237 $80
turbo owner 07-27-2015 01:24 PM
I found out our host sometimes uses different vendor for the same product and prices differ.
Example:$170 is Porsche, $120 OEM provider, $80 same as $120 just cheaper.
Call and ask them
VW_NUTT 08-01-2015 08:22 PM
Are you wanting this tool just to remove the bolt that holds the cam gear on? Use an impact and socket. Its not on that tight.
mreid 08-02-2015 06:35 AM
Off is easy, back on more challenging. Go with the cheap one unless you plan on many rebuilds.
gtc 08-03-2015 11:10 AM
The cheap one (SIR Tools brand) is plenty nice.
QSC makes a chinese knockoff also, which you can find for a bit less elsewhere (google).
