mixture/fuel milage
What are your experiences? I have a 2.7 hipo in a 71T. It has E cams, 9.5 JE, 35 intake manifold (67S?, 75 911S heads (35mm) and webers. exhaust is kinda smelly. At a steady 75 or 80 on interstate only, it gets 19 mpg. Around town probably 12 to 15 depending on how much I foot it. It is satisfactorily fast. Is this jetted too rich or is this normal for this setup? Thanks Henry
Get an AFR tester, then you'll know for sure. Doesn't seem unreasonable. Idles maybe a little rich.
Todd
'81 SC |
Without AFR information, anything further is just guesswork.
![]() What is your jetting configuration? Float levels Perfect?
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Reiver
Throw out the worthless clock and put an afr gauge in it's place....I monitor mine and adjust as required (usually when the Az heat hits and lowers air density and again in winter).
Usually slight adjustments but also lets me know if everything is working correctly...my wur adjusts enrichment under load (euro) yours prob the lamda but you'll know if it is properly working too. It tells you a great deal about your tune and you can split the dif. between performance and mileage. It also keeps you ahead of a blowing up air box.
De Oppresso Liber Strength and Honor 5th Legion |
Thanks for replies all but one very helpful (its a carbed 2.7 not cis and if anybody is hot for the complete cis sitting on my shelf let me know), The jetting is by the spec of the websters. AFR will be checked I'm not sure I want to see rwhp figures though. Mostly I hoped for others to say I get x mpg and this is my engine setup dyno hp etc. So on my similar set up with a 2.5 I also got 19 mpg on strict interstate at 75 and 80 mph. Maybe I should start a thread gimme your mileage numbers. best Henry
OK Black 993 I agree. just curious about mpg. I don't remember back 38 years when mine was stock. SSSOO if you 70 T is stock what mpg? or if not stock what is it and what does it get. thanks for response. best henry
Project Addicted
Maybe just head down to the local shop and have them stuff the gas analyzer up the pipe and get a base reading. Might cost $10....
I have a wide band setup that is very good to use for tuning. Almost too much info!! I get 23 on the hiway and 18 around town with my Ram 2500 with a Cummins :-) Jon
Jon 1966 912 1976 911 3.4 Backdate Project 1986 944 |
Slippery Slope Expert
Reiner, what sort of AFR gauge did you use to replace the clock? Was it made for the purpose or did you build it?
Reiver
[/IMG]
Thanks.
