-   -   3.2SS MFI twinplug....another one. (http://forums.pelicanparts.com/911-engine-rebuilding-forum/877614-3-2ss-mfi-twinplug-another-one.html)
BURN-BROS 08-04-2015 02:07 PM
Salutations!
I thought I would share a build we are doing for a friend.
98x70.4
10.5/1 CP pistons
Stock rods w/ ARP rod bolts (balanced and resized)
MFI (72T modded for bigness)
Twinplug by yours truely
Supertec head studs
DC 40 on new blanks
You can see addition photos on Facebook.
https://www.facebook.com/BurnhamBros/media_set?set=a.864516650264122.1073741855.1000011 73857266&type=3
http://forums.pelicanparts.com/uploa...1438721859.jpg
http://forums.pelicanparts.com/uploa...1438721896.jpg
http://forums.pelicanparts.com/uploa...1438722359.jpg
Cheers!
BURN-BROS 08-04-2015 04:14 PM
http://forums.pelicanparts.com/uploa...1438730037.jpg
BURN-BROS 08-07-2015 08:35 AM
The Car is a 1980 Euro SC Backdated to a 73 RSR. The MFI system we chose is from a 1972 T as it will give the customer an engine bay that conforms to 72/73 .
http://forums.pelicanparts.com/uploa...1438959892.jpg
Throttle bodies were rebuilt in-house. Housings were bored out for 40.5 throttle plates and 38mm intake ports. All hardware was plated, housings were pickled as close to factory as possible. New custom bushings were installed. upon completion, they were Flowbenched and ready to install.
http://forums.pelicanparts.com/uploa...1438959925.jpg
tharbert 08-07-2015 08:56 AM
http://forums.pelicanparts.com/uploa...1438962996.jpg
Tippy 08-07-2015 10:20 AM
Originally Posted by BURN-BROS (Post 8739510)
Awesome motor, but what is that V8 in the background?! That thing looks like a killer setup!
BURN-BROS 08-07-2015 10:35 AM
It's a New Boss block, Aluminum Cleveland heads, and a Boss 302 Hilborn setup. It's Mocked up checking port match. If things go according to plan, it should redline around 8200 rpm. It's slated to be dropped in a old mustang I have. More pics on Facebook about the build.
BURN-BROS 08-07-2015 12:58 PM
Fan refurbishment.
I sourced as early fan so that the Engine bay looked period. It was not in the best of shape, having moderate corrosion....but finding cherry parts is difficult.
http://forums.pelicanparts.com/uploa...1438976973.jpg
Nasty!...but workable. I know that I will not be able to remove all signs of corrosion. After quite a bit of work, the fan is treated to the same process as my throttle bodies. The results maintain all the details that the fan had originally, and a little more "history" presevation than other methods. Not perfection, but industrially handsome. :p
http://forums.pelicanparts.com/uploa...1438977354.jpg
http://forums.pelicanparts.com/uploa...1438977379.jpg
Notice the tonal difference where a worker trimmed the flash from the parting line in the above pic.
Customer should be happy with the results.
http://forums.pelicanparts.com/uploa...1438977445.jpg
BURN-BROS 08-11-2015 02:48 PM
Fan shroud fitment and mocking up the MFI. Amber Fan Shroud from Damon at Series 900.
http://forums.pelicanparts.com/uploa...1439329639.jpg
http://forums.pelicanparts.com/uploa...1439329653.jpg
BURN-BROS 08-12-2015 08:36 AM
http://forums.pelicanparts.com/uploa...1439393796.jpg
0396 08-12-2015 08:55 AM
Nice, looking forward to additional updates.
Harry998R 08-12-2015 02:55 PM
Hi Aaron,
Very nice looking motor!!
I was wondering if the colouring on the throttle bodies is as they came from the factory? The throttle bodies on my 72T are the same colour and I thought that they may have just faded over the years.
Cheers,
Harry.
BURN-BROS 08-12-2015 03:39 PM
Thanks Harry,
The 72-73 Throttle bodies vary in finish from very light to almost black. I have old factory photos of the engines when new that I use for both paint markings and overall finish. Ultimately the finish will be influenced by the condition the throttle bodies are in. Same goes for any of the Magnesium parts.
Originally Posted by Harry998R (Post 8750593)
Hi Aaron,
Cheers,
Harry.
Hcarraro 08-21-2015 06:20 PM
How did you "pickle" to get that nice dark grey surface? Looks fantastic.
Henry
BURN-BROS 08-22-2015 10:24 AM
Thanks Henry. That's a secret :cool: It took a long time for me to come up with it.
I can do a warmer gold finish as well as a cooler blue finish.
The Cool finish is the one in the pic and it is corrosion resistant. Meaning that it will not grow white fuzz just sitting out, but I wouldn't soak it in water.
Wired the alternator, installed updated crank bolt, Fan belt, shroud, cam feed lines and block offs.
http://forums.pelicanparts.com/uploa...1440263983.jpg
BURN-BROS 08-28-2015 05:19 PM
Waiting for a few bits. Almost complete
http://forums.pelicanparts.com/uploa...1440807479.jpg
http://forums.pelicanparts.com/uploa...1440807500.jpg
http://forums.pelicanparts.com/uploa...1440807515.jpg
cnwayland 08-28-2015 08:57 PM
That's a very fortunate friend! Beautiful work, especially enjoy the shroud color.
Trackrash 08-29-2015 09:39 AM
What heads are you using? Modded SC heads?
BURN-BROS 08-29-2015 09:54 AM
Heads are big port 78/79. The CIS notch was welded up and drilled for the MFI injector.
BURN-BROS 09-09-2015 09:54 AM
Just finishing up a few things on the engine today, then it's off to be installed.
http://forums.pelicanparts.com/uploa...1441817500.jpg
http://forums.pelicanparts.com/uploa...1441817573.jpg
KTL 10-22-2015 11:12 AM
Hi Aaron,
I had a question about how you approach the position of the injector fitting on the later head. Seems logical that the position is "centered" toward the middle/quadrant of the intake port. But is the angle just a matter of setting it such that it clears the throttle body?
At first I was thinking it could be angled just like a CIS or Motronic injector. But then I realized it would probably hit the MFI throttle bodies at such at angle.
Just trying to get a feel for how different the angle is from an MFI arrangement vs. the later CIS or Motronic.
Also, what are your thoughts on the CP pistons? Just curious how they differ from the JE usual suspect.
Kevin
BURN-BROS 10-22-2015 11:41 AM
Originally Posted by KTL (Post 8846842)
Hi Aaron,
Just trying to get a feel for how different the angle is from an MFI arrangement vs. the later CIS or Motronic.Kevin
I have the angle somewhere, but I just use a factory head to quickly get my angle and position. Yes, it can hit the throttle body as it is a tight area.
Kevin
So far I like working with them. The big difference is I have much more control in the design of the piston. I get a solid model and theoretical weights prior to placing an order. Something I never got thru J.E. Other piston manufacturers do the same thing, but getting direct feedback from an engineers can be difficult.
KTL 10-22-2015 01:10 PM
Thanks for confirming my suspicion & thanks for your insight on the CP pistons.
philippeF 10-24-2015 04:13 PM
Hello
It's often difficult to machine the plastic stacks, Did you bore them ?
Philippe
BURN-BROS 10-24-2015 04:39 PM
Originally Posted by philippeF (Post 8849714)
Hello
Philippe
Hi Philippe,
I bore both plastic and mag stacks inhouse. These were bored 46mm top and 41mm bottom. They are matched to a set of throttle bodies that were bored to take 41mm throttle plates.
philippeF 10-24-2015 04:43 PM
Nice work !
BURN-BROS 10-25-2015 10:04 AM
Thanks!
pff 01-03-2016 01:38 AM
Hi Aaron,
I just have to say i love your work on this engine and i want to do the samething on my 3.0!
But i like to know howmuch hp and torque this set up will generate?
Cheers,ferry
BURN-BROS 01-03-2016 12:03 PM
Hi Ferry, Horsepower is around 280 hp depending on the exhaust you choose. With a little more cam and a little less exhaust you can see 300hp.
PorscheRally 01-08-2016 01:07 PM
Hi Aaron,
Beautiful build. Congratulations.
I was wondering which method and media you have used for cleaning the case and all the other alloy to this brand new level ?
Cheers,
Kerem
BURN-BROS 01-10-2016 02:32 PM
Thanks Karem,
I sub contract to a company that specializes in surface preparation. They are usually involved in the manufacturing industry and prep castings and machined parts. The service is not cheap, but the result is a very consistent and appealing finish.
al lkosmal 01-10-2016 05:21 PM
Nice build details Aaron.....good blend of mechanical know-how and aesthetic sensibility.
regard,
al
BURN-BROS 01-11-2016 08:32 AM
Thanks Al, the engine turned out very strong and is a great fit for the car.
http://forums.pelicanparts.com/uploa...1452529777.jpg
http://forums.pelicanparts.com/uploa...1452529903.jpg
Flieger 01-11-2016 06:47 PM
Ooh, Mark's got a new motor? Sweet!
al lkosmal 01-11-2016 07:00 PM
oh yessss....that looks like fun!
regards,
al
