Question 911 T 1970 connections
Hello,
I am taking out the engine to install Carrera Tensioners and found 2 openings not connected can anybody help me
A goes to the nipple at the bottom of the air filter housing
B goes to the small nipple at the back of the air filter housing
C ???
D goes to the pipe at the back of the air filter
E goes to the top of the oil reservoir
F goes to the oil filler from the filter at the back of the air filter housing
G ???
Thank you !
Old 03-19-2015, 03:27 AM
One of the smaller hoses attaches via a nipple on the shroud behind the Fan and alternator. That may be the 'C' hose.
Still some mystery to be solved by a sharper eye.
Rusty
71 911E
55 PreA speedster
85 Turbo look Cab
62 Twin Grille Roadster (getting close)
Old 03-19-2015, 08:20 AM
Thank You ! Indeed there is a nipple on the fan shroud what would the use be of pipe C ?
Old 03-19-2015, 11:13 AM
E Sully's Avatar
The connection on the shroud is part of the fuel venting, charcoal cannister system.
Ed
1973.5 T
Old 03-20-2015, 05:14 AM
Thank You all
Still wondering what the hole G is for any help ?
Old 04-16-2015, 03:19 AM
G... How about the rear bumper extension support
Bruce
Old 04-16-2015, 03:43 AM
Believe 'G' is for a warm up hose going to the air cleaner snout.
Old 04-16-2015, 06:57 AM
Under the radar
Trackrash's Avatar
^^^^ True. If your air intake snout was modified or removed this hose may have been eliminated. It was only there to please the Smog Control Gods.
Gordon
'71 911 Coupe 3,0L outlawed
Old 04-16-2015, 09:20 AM
THANK YOU VERY MUCH ALL OF YOU
I also have a non isolated electrical connection that goes to the right side near the ventilator that I don't know what it is for
Old 08-09-2015, 02:55 AM
Tags
1970 , 2.2 , lines , pipes
