-   -   BTR motor rebuild (http://forums.pelicanparts.com/911-engine-rebuilding-forum/881347-btr-motor-rebuild.html)
rpsurfr 09-01-2015 12:35 PM
BTR motor rebuild
I have a 1981 BTR that needs a complete motor- I might as well, as there is no compression in two of 6
My question is who to trust with this motor. I have RUF paper work it was put together in Germany by RUF as well as a 5 speed hook up.. I wantit done to specs to preserve the car.
So thoughts gentleman?
thank for your help
Doc
JFairman 09-01-2015 01:02 PM
I guess that depends if you want it done locally or you want to ship the motor somewhere else. There's a lot of people that can do a good job rebuilding it.
dennywags 09-01-2015 01:36 PM
Perfect Power in Buffalo Grove, IL used to be a Ruf dealer and I know he has built a few BTRs.
Spenny_b 09-01-2015 03:59 PM
Chris @ TurboKraft
0396 09-01-2015 04:09 PM
Steve W@ Rennsport Systems
rpsurfr 09-04-2015 02:30 PM
thanks all
Turbo_pro 09-04-2015 04:59 PM
Supertec Performance
Henry Schmidt
760-728-3062
supertec1@earthlink.net
They built both of my 930 engines.
3.1 has 15 years of use and 3.5 has 11 years.
Zero issues. I just wish they would work on water-cooled as well.
http://forums.pelicanparts.com/uploa...1441411113.jpg
porterdog 09-04-2015 07:26 PM
Not to take anything away from any builder mentioned in this thread but last I knew the NA Ruf distributor was in Southfield... Probably worth a phone call given your proximity.
TurboKraft 09-16-2015 03:05 PM
Done several BTRs and BTR-IIs.
Here's one we did in 2013. The owner already had a carbon fiber fan shroud and had painted his fan red, wanted to keep both, so we refreshed them while remanufacturing everything else to as-new condition.
(Yes, 1-3 air duct missing, we were waiting on one from Germany.)
Even remanufactured the unique "Grosse K27" -- no, those are not the same as the old K29/27 hybrid turbos everyone built.
http://forums.pelicanparts.com/uploa...1442440969.jpg
http://forums.pelicanparts.com/uploa...1442440979.jpg
http://forums.pelicanparts.com/uploa...1442440992.jpg
http://forums.pelicanparts.com/uploa...1442441021.jpg
blue911rsr 09-16-2015 05:58 PM
Done a twin turbo ruf right here in Kalamazoo not to far from you car was later sold at gr auto gallery
Claudio
Matt Monson 09-18-2015 08:09 AM
I wouldn't put much stock in who was a Ruf distributor. Some of the operations they have licensed over the years haven't been the best. You want to pick a good engine builder. It doesn't matter much whether they have a Ruf history or not. There's some good ones here.
For an engine I like to work with someone local so I can manage the job. Too many long distance blackhole stories around here. I'd probably call Claudio first and talk to him about it.
