Quickie piston ring question
Hi engine folks. I am staring at my set of JE 10.5 compression pistons for 98mm bore in a 3.0 liter motor. And I cant find any definitive instructions on how to install the rings. There are two compression rings that are the same. Do they both follow the same orientation, IE are they both "top" side up when I install? If anyones been down this road before, thanks for your experience. Tried calling JE but nobodys home right now and I dont blame them.. Friday on a holiday weekend!http://forums.pelicanparts.com/uploa...1441404633.jpg
http://forums.pelicanparts.com/uploa...1441404656.jpg |
Top should face you as you look at the top of the piston
http://forums.pelicanparts.com/uploa...1441406976.jpg |
| All times are GMT -8. The time now is 08:50 PM. |
